Can I set a timer on my Versa 3?
ANSWERED
Does anyone know if the Versa 3 can provide a split timer?  For example, I would like to be notified at 3 minutes and 5 minutes for 30 minutes.  Thank you.
1 BEST ANSWER
Accepted Solutions
Would have to do it as separate timers.  Can have up to 3 different timers going at same time.
3 REPLIES 3
Hi there, @ValAnn. Welcome to the Community Forums.
I agree with @JohnnyRow. For more information, see How do I set a timer or use the stopwatch on my Fitbit device?
Also note that when you choose Interval Workout from the Exercise App on the Versa 3, you will see a tiny "^" at the bottom of the screen. Swipe up, the icon to set your intervals is in the upper right.  You also get other setting options there, like using GPS, customizing your display stats, and Always-On. For more information, see How do I track my workouts with my Fitbit device?
See you around.
Hi @ValAnn - what @JohnnyRow says. If you don't mind staying in a timer App, have a look in the Gallery, I've seen some timer apps with multiple timers [but perhaps not for Versa 3] or SimpleTimer  which has a repeat function for currently only one timer which may be useful. The problem is you can't combine two ordinary apps at once.
You are more likely to find what you need for a phone, and with that you could possibly setup notifications to come to the watch, though the standard Android one may not raise notifications so you will need one that does.
A later version of SimpleTimer may support multiple timers with repeat which could meet your need.
Also explore the use of Voice Assistant, it may be able to create what you need.
