02-12-2020 11:39
02-12-2020 11:39
Is there any way to customize the display on a Versa Lite to show the current battery level? It shows it briefly (and also if you tap it) when you put it on the charger but I'd like to be able to see it while I'm wearing it. Doesn't need to be on the clock face screen but I can't find it anywhere while I'm wearing it. My wife's Alta HR shows battery status as one of the things you see if you tap through the other stuff (steps, heart rate, etc.).
Best Answer02-12-2020 12:08 - edited 02-12-2020 12:10
Yes, Bob, Swipe up to the Today screen and the battery % is at the upper left. And if you want it all the time, there are lots of clock faces that have it.
Best Answer02-12-2020 12:44
02-12-2020 12:44
WOW! Thanks a lot. I didn't know about swiping up (for anything). More good stuff there!
Best Answer02-12-2020 16:46
02-12-2020 16:46
Lots of good stuff in the User Manual.
Best Answer02-12-2020 17:00
02-12-2020 17:00
Thanks. I do appreciate your help.
Best Answer06-13-2020 07:37
06-13-2020 07:37
Try SimpleClock, it has a log and a prediction of when charging is complete, along with an always on display while charging showing current time.
If you choose not to use the always on feature it shows you each time the battery level changes.
https://gallery.fitbit.com/details/b3d7fabf-4cb1-4e58-9253-19697ce22800
