04-26-2018 10:45
04-26-2018 10:45
Hello,
I have that basic question because I need to see if the sea water is going to harm my Fitbit at all?
Thanks for the response.
04-26-2018 12:51
04-26-2018 12:51
Fitbit Versa is “5 ATM” or “Water-Resistant to 50 Meters”. Or, put another way, it withstands pressures equivalent to a depth of 50 meters.
But water resistant ISN'T waterproof.
There is no such thing as a waterproof device. Every product, no matter how carefully engineered, has a failure point. Every smartphone, every smartwatch, every wearable, every “waterproof” camera, every single device, has a point where a combination of water temperature, depth, length of exposure, or manipulation of the device while submerged, will lead to a failure of the water resisting.
The Versa is well-rated for submersion below shallow depth while swimming.
As for salt water, I wouldn't swim with my Versa in the ocean. When saltwater gets inside a device, it can affect the hardware in two major ways: it can short circuit the device and cause corrosion or buildup. I use my Fitbit devices while sailing on the ocean, but not while I'm swimming in it.
04-26-2018 11:43
04-26-2018 11:43
I dont see why it would harm it if it can already go down 50 meters. I would wash it with fresh water once you get out though.
04-26-2018 12:16
04-26-2018 12:16
The reason why I ask this, is because "Sea Water" damages a lot of electronics, for what I've seen... and its different from river water or pool water.
04-26-2018 12:39
04-26-2018 12:39
I wouldn't try it. Will it get water damage? Probably not. However, the salt in the salt water may cause some damage.
one cruise ship at a time!04-26-2018 12:51
04-26-2018 12:51
04-26-2018 16:26
04-26-2018 16:26
I wouldn't. The pins in the bands will corrode with regular exposure to salt water.
04-26-2018 20:22
04-26-2018 20:22
Pebble has similar pins I would swim with that in the gulf often for the past 2 years.. if you rinse it off with clean water afterwards it's okay. The worst thing would be a salt could get into the button area... Pebble 2 doesn't let anything in but this might.
07-29-2018 00:12
07-29-2018 00:12
Hello there,
Thank you for your answer.I agree with most what you said but as a swimmer i bought the versa especially because i can swim with it and not think about it.
So you are telling me that if i keep swiming with it and monitor my swiming activities, my waterresistant watch will stop working some day ? Great
08-14-2018 09:44
08-14-2018 09:44
I used my Versa for swimming in the pool multiple times over several months with no problems. Then I used it to swim in the ocean (shallow water up to 10 feet) the other day and immediately began having problems with the battery not holding a charge for longer than a few hours. Not sure if it was just coincidence but I'm glad that fitbit is replacing my Versa at no charge since it is under warranty. However, I will not go swimming in the ocean with my new one.
08-24-2018 18:33
08-24-2018 18:33
I spent 10 minutes splashing around in the ocean and my Versa failed immediately- no corrosion or buildup possible. I'm now on my 3rd Versa. Customer service is not very responsive. Fortunately I bought it at a store that has a generous return policy.
08-24-2018 18:35
08-24-2018 18:35
Get a Garmin. My husband swims daily with his! I swam for 10 minutes and my Versa failed!
12-28-2018 23:13
12-28-2018 23:13
I already had a Fitbit Flexi specially for swimming and it lasted three months only in a pool and I’m wondering about my new Versa in the pool can I risked it
12-29-2019 11:44
12-29-2019 11:44
Do not swim in Ocean with your fitbit.
I just cooked my Ionic. The salt kills it.
I have swam many times in pools and fresh water lakes with no problem, but the Ocean will ruin it.
SB
12-30-2019 06:47
12-30-2019 06:47
01-21-2020 20:43
01-21-2020 20:43
Same thing happened with my versa after a few weeks swimming in the ocean. I’m not going to risk it with my replacement.
03-03-2020 08:04
03-03-2020 08:04
I wouldn't. Saltwater is highly conductive and the charging pads are exposed on the back of the watch which could easily short out causing poof!
03-28-2020 10:28
03-28-2020 10:28
so the reason I bought the watch was to track my activity. Salty sweat must kill it too. Nice
06-20-2020 18:46
06-20-2020 18:46
Don't do it. I just got back from a trip where my Versa was exposed to saltwater. The first time was brief and I noticed the screen acting up, it was stuck scrolling through apps screens. It stopped and started working properly again. A couple of days later I wore my versa in the ocean again, for about 30 - 45 minutes this time. It died. At first, it was still sending alerts and counting steps but the screen was blank. Then, when the battery died, it would not recharge.
06-21-2020 06:28
06-21-2020 06:28
09-12-2020 06:28
09-12-2020 06:28
It's too late for you now. And too late for me. But hopefully others can be saved!
I was stupid enough to swim in the sea with my Versa this summer
8 months of twice weekly swimming in a pool tracked my activity automatically like a dream.
After three days in the sea in Italy the left button went. I struggled on with the 'lift your hand to see the time' function. Then that went and I couldn't change the screen at all. Then the bluetooth connection to my smartphone went
It died a painful death over the course of a week. Now it's gone. Out of warranty, I will get another but be a bit more careful!
