04-19-2018
10:32
19:24
EdsonFitbit
04-19-2018
10:32
19:24
EdsonFitbit
I have two phones, one for work and one personal (both iphones). When I got the Versa I was under the impression that I would be able to switch between the two phones. Is that possible?
Moderator edit: added label
04-19-2018 14:37 - edited 04-19-2018 14:39
Hi @KelseyEliza,
Sure, I don't see why not. Just install and log in to the app on both phones. Whichever phone you're using will sync the data to Fitbit's servers.
I wouldn't try to use the app at the same time with both phones (the Versa's bluetooth won't connect to both simultaneously), but for switching between two, it should be fine. It's probably best to not try and sync when both phones are in range of the Fitbit. Make sense?
04-19-2018 14:41 - edited 04-19-2018 14:42
@KelseyEliza Yes and no, you can because your data is synced to your account, not your phone. But also no, because you can't have both connected at the same time. If you want to connect to your work phone, you have to turn off Bluetooth or disconnect (forget this device) from your personal phone and vice versa for your personal phone. But once you disconnect your Versa from your phone, you can connect it again, although if the phone is a little older (older than iPhone 6 I'm guessing) it might take a while and something won't connect, you have to restart your phone a wait for your phone to find your Versa or sometime it won't pair until the next day (what happened to me yesterday). So yes, it's possible, but it takes time and sometimes it won't work. I switch between my iPad and phone, they both are super old (iPad 2nd gen iPhone 5c) so it takes forever to switch and sometimes it won't find my Versa.
Want Spotify for Versa? Click Here to Vote!
Click Here to Vote for Low Power Mode!
