09-26-2018
20:12
06:57
AlejandraFitbit
09-26-2018
20:12
06:57
AlejandraFitbit
Are you able to turn off the heart rate monitor? Or is it always on?
Cheers!
Best Answer09-26-2018 21:37
09-26-2018 21:37
Hi, @ceejames! Very easy fix, on your tracker, swipe over to settings, scroll down to heart rate, and tap to turn from on to off.
MakMak | Community Council
09-26-2018 21:37
09-26-2018 21:37
09-27-2018
06:59
04:30
09-27-2018
06:59
04:30
04-04-2019 01:27
04-04-2019 01:27
Hi James,
Have you solved the problem or not . my versa that the sensor is always on for it. I have to charge my versa once a day.
02-14-2020 11:13
02-14-2020 11:13
Mine will not turn off either. It’s always on. I tried adjusting my settings with no success.
02-14-2020 11:15
02-14-2020 11:15
This hasn’t worked for me.
02-14-2020 20:54
02-14-2020 20:54
It doesn't work for my versa lite too. The sensor led is still flashing.
07-05-2020 20:21
07-05-2020 20:21
I am also looking to turn off the sensor. Has anyone figured out how? The heart rate is turned off on the Versa Lite but the sensor still flashes green. I will return it if the feature to turn off the sensor is not available.
Thank you in advance!
07-10-2020 07:27
07-10-2020 07:27
07-10-2020 07:42
07-10-2020 07:42
Thank you! I may do the same.
05-07-2021 05:53
05-07-2021 05:53
Mine too, it won’t turn off. I don’t have the option on and off in setting on the watch.
i did it on the app but still going.
i have a versa 3
06-20-2021 19:01
06-20-2021 19:01
I reckon after being bought by Google, they have increased trackers. Don't think we even fully turn off the voice and yet alone heartrate monitor.
It was much better and privacy friendly before November 2019.
Thanks Google! Imagine paying hunders of dollars and enabling them to evade our privacy. Great! Go NSA!
Best Answer06-20-2021 21:42
06-20-2021 21:42
Can't even delete my comment? Amazing.
Best Answer01-27-2023 17:12
01-27-2023 17:12
Can I do this on my tablet
Best Answer01-27-2023 19:18
