07-19-2018
18:47
09:38
HeydyF
07-19-2018
18:47
09:38
HeydyF
Why can't I use the music controls while I am exercising? It seems to pause my run if I try to do it. It appears as if I can't even look at the time without pausing the run. Am I missing something?
07-20-2018 09:54
07-20-2018 09:54
Hey @tiffanyversa, welcome aboard! You should be able to control your music while exercising, either with Running or by doing any other activity; and of course you should be able to look the time as well. Let me suggest you something, please take a look at the instructions in this help article: How do I control music my Fitbit device?
Let me know if you have further questions!
07-20-2018 09:56
07-20-2018 09:56
Sure you can @tiffanyversa as explained in the User Manual, to access music controls, simply hold in the left button. This is the same as when accessing from the clock and will work from any screen.
We can also go to fitbit's help docs.
02-27-2019 11:49
02-27-2019 11:49
Did you ever figure this out? Its very annoying not being able to control the music while using the exercise function. Is there a way to see the time as well? Both pretty important features for a "Smart Watch". These other responses were crap.
02-27-2019 11:54
02-27-2019 11:54
I control my music while exercising with the buttons of my bluetooth headphone...
02-27-2019 13:00 - edited 02-27-2019 13:04
Seeing the time is easy during the exercise tracking @DozerDave , simply swipe the display to the time
This is explained in the Versa user manual.
To gain access to the basic music controls, Fitbit pay, or quick settings, hold the left button in.
@danyelefausto by holding in the left button you will get access, on the wrist, to the same music controls found on the headphones.
This thread is about getting direct control of the Deezer or Pandora to be able to switch channels.
For this feature to work we will need to move the exercise recording into the background the easy the stopwatch can be moved.
However this may not be possible considering all the computer power needed during the recording of am exercise.
