10-04-2018 13:02
10-04-2018 13:02
10-04-2018 14:30
10-05-2018 12:54
10-05-2018 12:54
Hello @AndrewX, welcome to the Community! Just like @WavyDavey said, there is no way to replace Versa's battery. If you have issues with it, like, for example that it is not lasting as expected, I would recommend you to take a look at the tips in this post to make it's battery last longer. If there is other issue with your Versa, let me know, and I will help you out. 😉
I'll be around!
11-23-2018 10:13
11-23-2018 10:13
I join the others of this online community that are having problems with Versa battery life. I noticed that the intervals between charges was getting shorter and shorter until finally the watch stopped charging altogether and I cannot turn it on. The screen is black What's my next step?
Thanks!
11-24-2018 08:10
11-24-2018 08:10
Hello @NDudley, let me give you a warm welcome to the Community! If your Versa won't turn on, I'd like to know if you have tried to restart it. If not, please follow these instructions:
Let me know if that works!
11-25-2018 01:30 - edited 11-25-2018 01:33
Thank you for your response! Yes, I had tried restarting my device several times. Number 3 per your instructions wouldn't be applicable because I can't access the settings menu on my Versa because it won't turn on.
What next?
11-26-2018 05:57
12-19-2018 05:46
12-19-2018 05:46
I'm having the same issue. Everything turned off with default watch face and the battery went from 100 at 14:00 to 0 sometime prior to 0600 the following day. Very disappointed in the battery life. If turning off all of the features is the only way to potentially have the watch last more than a day, what is the point of having this watch over a plain watch?
12-19-2018 07:26
12-19-2018 07:26
Let me give you a warm welcome to the Community @Jesseraphael! Considering that the battery of your Versa is not even lasting a day, I have escalated your case with our Support team for them to further assist you, so please keep an eye on your inbox.
Let me know how it goes!
12-20-2018 23:03
12-20-2018 23:03
@Jesseraphael wrote:I'm having the same issue. Everything turned off with default watch face and the battery went from 100 at 14:00 to 0 sometime prior to 0600 the following day. Very disappointed in the battery life. If turning off all of the features is the only way to potentially have the watch last more than a day, what is the point of having this watch over a plain watch?
@Jesseraphael I would call support! I leave all my notifications on etc. And still get at least 4 days of battery life. I noticed others on the forum had this same problem as well and some have gotten replacements. My Fitbit did this once or twice but a reset fixed the issue.
Best Answer01-11-2019 00:29
01-11-2019 00:29
I too am.having this problem! I'm having to charge my watch at work now
01-11-2019 01:03
01-11-2019 01:03
... and another, I am getting 7-8hrs max before the Versa completely dies 😞
01-19-2019 11:32
01-19-2019 11:32
Hey @SineadFitz91 and @eSSeMM36, welcome to the Fitbit forums guys! If the battery of your Versa isn't lasting as expected, I suggest you to take a look at the tips in this post, to make it's battery last longer. Give it a try and if the issue persists, let me know.
I'll be around!
01-31-2019 05:47
01-31-2019 05:47
So I reviewed the tips on the battery and basically it says turn off all the functions that I purchased the watch for and this basically makes the watch useless to me. I will not be purchasing another Fitbit product. Why would you make an expensive watch Ike this and not give a battery replacement option? Is it because you make more money selling a new watch. Very disappointed in this product. I will be changing to Apple because they will replace my battery.
02-15-2019 01:44
02-15-2019 01:44
I get the same experience 😞 I bought my fitbit versa just last Oct 2018. Not even half a year and im already having probs with my batt 😞 HELP!!!
02-15-2019
09:02
08:09
02-15-2019
09:02
08:09
Hey @Persian26814, let me give you a warm welcome to the Fitbit Community! I apologize for the delay in answering your post and sounds bad that the battery of your Versa is not lasting as expected. In order for you to get further assistance, I suggest you to get in touch with our Support team so they can review your case and provide you with different options to get you back on track.
@Ehmcie, Welcome aboard! How long is the batter of Versa lasting? By any chance, have you reviewed the tips in this post to make it's battery last longer? If you haven't, please give it a try.
I'll be around!
Best Answer05-11-2019 13:14
05-11-2019 13:14
Wow, I am also not getting a battery more than a day and they claim that it has a 4 day battery.
I got mine as a Christmas gift am super disappointed.
Maybe you should make a Fitbit with a warranty for replacement if you can't make it with a battery that you can replace.
I bought my daughter a Fitbit Alta last May and she hasn't had any problems with her Fitbit.
Pretty hard to believe that something this expensive that we willingly pay alot of money for is such a bad product.
Alice Phipps 11@yahoo.com
05-11-2019 15:12 - edited 05-11-2019 15:38
I had mine replaced by support back in December. My replacement is now doing it. I’ve tried all the tips I was given before we did the battery test and they ended up replacing it because it was lasting less than 24 hours. This replacement is now lasting a day to a day and a half. I agree with everyone else, why buy a watch if you have to turn off all the features? I’ve had 4 different Fitbit watches and never had a problem til I got the Versa. That’s a lot of money to spend just to have to turn everything off to try to keep the battery charge. I’m so frustrated, I bought my original one almost a year ago. So thats 2 that won’t keep a charge. Many others on the forum here have had them replaced a couple times. So what gives?
06-08-2019 07:54
06-08-2019 07:54
Mine took 14 months for these issues to start so I guess I feel lucky. However I was told by Fitbit customer service that unfortunately they cannot replace it since it’s outside the 1-year warranty window. I did get the 2-year extended warranty but I guess that doesn’t cover poor battery design. They did offer me 25% off a replacement because this is clearly a product I would want to buy again. Everyone should do themselves a favor and stick with the cheaper Fitbits that are made with higher quality. If you want a watch, go with Apple.
06-14-2019 13:24
06-14-2019 13:24
I’m having the same issue.. screen totally black and won’t turn on or off....
For two days had to charge each day as the battery totally drain in less than 24 hours. Yesterday it wouldn’t charge at all. Tried to restart several times. Bought a new charging base. That isn’t the problem..
