01-19-2022
11:14
20:34
01-19-2022
11:14
20:34
Can anyone help? I got my Fitbit versa 3 for Christmas and although I’m glad i can receive and answer calls no one can hear me properly on the other end it’s very frustrating!?
01-20-2022 05:32 - edited 06-01-2023 06:17
Hi there, @Mel3461 @SunsetRunner. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand how frustrating this can be.
If you haven't done so yet, please check the following requirements:
If you continue having issues, try the following troubleshooting steps:
Note that Versa 3 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
On a side note, please note that if you're trying to connect any headphones while using on-wrist calls, specially Airpods, at this time Fitbit smartwatches can't control the volume on Apple Airpods.
Hope this helps.
01-19-2022 16:02
01-19-2022 16:02
I'm having the same problem with my versa 3. Everything else works,-notification, volume, switch between phone and watch, I can hear them but they can't hear me through watch
Hope this helps.
01-20-2022 17:26
01-20-2022 17:26
Thanks Marres. I have the latest update and I've done all of the above several times with no resolution on this problem. I was not using headphones so that is not an issue
01-21-2022 04:37 - edited 08-10-2023 04:00
@SunsetRunner I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
