06-24-2022
10:01
17:53
06-24-2022
10:01
17:53
06-24-2022 11:48 - edited 06-24-2022 11:49
Hello @TvdBroek
Can you make sure you don’t have Focus enabled or Do not disturb enabled by accident on your Phone.
The easiest way to tell if a Focus or Do Not Disturb is turned on is to open Control Center and look in the upper right-hand corner of your iPhone, just to the left of the battery icon. If a Focus is enabled, you’ll see the corresponding Focus icon there. If Do Not Disturb is enabled, you’ll see a small moon icon there.
😃 Let me know if this helps answer your question
06-25-2022 11:52 - edited 11-16-2023 03:01
Hi there, @TvdBroek. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your phone. @SunsetRunner Thanks for helping out!
If you want to switch a call from your Versa 3 to your phone, please follow the steps below:
Note that if you answer a call with your phone, you can’t switch the call to your watch.
For more information about this feature, see How do I take on-wrist phone calls with my Fitbit smartwatch?
Hope that helps.
06-26-2022 06:25
06-26-2022 06:25
Unfortunately this is not the problem
Best Answer06-26-2022 06:30
06-26-2022 06:30
Unfortunately this is not the problem, the recipient can't hear me.
Best Answer06-26-2022 07:07
06-26-2022 07:07
@TvdBroek I think your post became a little confusing when the moderator clarified your subject. Are you saying that the recipient can't hear you when you answered the call on your Versa 3? Or that you answered a call on your phone and the recipient can't hear you when you speak into your phone?
I don't have on-wrist calls set up on my Versa 3. But I might have an answer for you if it is the first question. I reviewed this YouTube video posted by a very reliable reviewer. There is something that is never mentioned. There is a separate microphone setting in the Versa 3 Settings app. Settings > Vibration & audio. Do you have your microphone toggled to on? I experienced a similar situation with the Snore detection feature. Everything gets set up in the app. But you need to turn the microphone on in the device settings for it to work.
Laurie | Maryland
