Can my Versa be partially charged before wearing next?
My Versa says it’s 96% charged but the app, with which it just synced, says it’s fully charged. Which is correct and can I charge it partially before wearing it again without causing the battery to assume it’s full and stop at that level of charge from then on?  My mobile syncing device is an iPhone 8, syncing via the Fitbit app.
3 REPLIES 3
 You should be fine but i would keep an eye on it as it should show fully charged
Community Council Member
Wendy | CA | Moto G6 Android
If it shows a full, green battery that jus means that the battery is high and it does not need charging, orange half battery means that it is not charged all the way but the battery is not low, the red battery means you need to charge it.
Android and iPhone 6s. Versa, Flex 2, and Zip
