Can not get text on Versa 3
Have tried everything that I have read but can’t get texts to show up on my Versa 3.
Anyone know of a fix ??
7 REPLIES 7
Hi @Perry304 - just in case did you swipe watch face to the right to get to Quick Settings and check neither sleep nor do not disturb are enabled.
If you setup under Versa 3 notifications and app notifications correctly and the notifications are appearing on the phone , make sure your watch is syncing properly.
You can always in the Fitbit App, click profile photo, Help & support, Contact Customer support.
I get phone calls & notifications from my garage door app , just no text
@Perry304- thanks, do you see pop up notifications for text on your phone?
When you click profile photo,device photo, Notifications, have you the right app selected for text messages, you can also lick app notifications and add other apps for text messages.
Yes I get a pop up notification on my phone when I receive a text. I also don’t get any other push notifications from fitbit
@Perry304- on the off chance, swipe the watch face right and check that neither Sleep nor Do not disturb are enabled.
yeah , checked that
ok , I figured it out. On my phone went to Settings > Messages > Notifications , under lock screen appearance / show previews / Always
