Can only add gym, walk and biking manually
I have a Versa 2. When I click on the + to add an exercice, and then choose to log it manually, I can't find any exercice except walk, gym and biking.
2 REPLIES 2
Go to dashboard.
Select your icon picture top left.
Select your Versa 2.
At the bottom you can find exercise shortcuts.  Swipe left and remove 1 (you are able to add up to 7, but for some reason you must delete one to get the full list.   You may always readd the exercise).
Once you are able to see the full list, you may add or remove some exercises.
Thank you but it still isn't working... to make sure we understand the same thing, it's in my Dashboard that I don't see the full list, not on my watch.
Dashboard
Exercices (where we see for example 1 of 3 this week) - I click on the +
Then I see the tracking, but I choose the other option at the top (mine is in french but it's the option to enter manually)
And there I see only 3 exercices, and even if I use the search bar I don't find anything...
