09-26-2018
10:58
06:19
AlejandraFitbit
09-26-2018
10:58
06:19
AlejandraFitbit
Hey,
I have two cards on my Fitbit app that have been already been registered. However, when I try to sync them to my Versa, it gets stuck in an infinite syncing loop. I tried factory resetting the Versa, deleting and reinstalling the app on my phone as well as removing and re-adding a card.
09-27-2018 06:20
09-27-2018 06:20
It's great to welcome you @Sherwyn.
I appreciate all the efforts in trying to fix this issue and recommend verifying that you are doing the following:
Let me know the outcome.
09-27-2018 06:20
09-27-2018 06:20
10-15-2018 06:28
10-15-2018 06:28
Thanks Alejandra. I tried your solution but it didn't work the first time. After I factory reset the device, it worked. However, I had to wait like for an hour or so for the App to sync the card to the phone. Anyways, it works now and thanks for the help!
10-17-2018 04:02
10-17-2018 04:02
Those are great news @Sherwyn.
I am glad to hear that your issue has been resolved. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
02-10-2022 02:34
02-10-2022 02:34
I have followed the above instructions but get and answer, you need to use a password or thumb print. I really need the wallet with my card as it says time etc. I have removed VERSA 2 from Fitbit, gone back to factory set up and entered a Pin but no luck, can someone ring me to help further
02-10-2022 03:43
02-10-2022 03:43
Does a factory reset clear all of your data? I’m at my wits end and willing to try this because I am not getting my SleepScore among other things after the latest update
02-10-2022 19:39
02-10-2022 19:39
02-10-2022 19:47
02-10-2022 19:47
Deleted Versa 2 from my FitBit, did factory reset and went through total process. The process did not ask me to introduce a PIN. Still getting message “Fitbit requires Touch ID or password…
not good at this stage as I cannot include credit card
