02-27-2019 16:38 - edited 10-31-2019 14:17
Fitbit Update: 6/5
Hey there, Versa Fam!
Thanks so much for your patience with this issue of clearing notifications from the watch. Our team has identified a fix for this that will release in a future firmware update.
I'm not sure when the next firmware update will be rolled out, just know it should include the fix for this. In the meantime, please give your Versa a restart if you have trouble "clearing all" the notifications off. After the restart, your notifications will be gone.
Fitbit Update: 2/27
Hi everyone!
I just wanted to follow-up with you all that have come across any difficulty clearing notifications on their Versa. I've experienced this myself a few times and a restart has always resolved the problem. Please give the watch a restart as your go-to troubleshooting step.
Our team is aware of this ongoing problem and working on a permanent fix. Please stay subscribed to this thread for future updates on this topic.
06-18-2019 22:48
06-18-2019 22:48
Restarting my iPhone actually corrected my problem & the notifications all started coming in at the same time, so its been running smoothly since then. Thank you. ![]()
06-18-2019 22:53
06-18-2019 22:53
thanks Ginofs, restarting my iPhone is what did the trick & everything has been perfect on my Versa Lite ever since then. Just like you said, I was flooded with a bunch of notifications after the restart but I sure am happy its back to doing its job now. thank you again ![]()
Best Answer06-26-2019 11:11
06-26-2019 11:11
Hi, great news that the development team is working on a fix for this. Any news on when this might get rolled out? I'm having to restart my versa once every day or two just to clear out the notifications and it would be great not to have to do that anymore. I'm really hoping the firmware update isn't months away...
07-04-2019 12:47
07-04-2019 12:47
Thanks for trying to fix it this issue has enoyed me for so long 😕
Best Answer07-05-2019 07:36
07-05-2019 07:36
If I were to restart it would my personal achievements and data be lost also?
Best Answer07-05-2019 07:56
07-05-2019 07:56
Sync first. But no. They are stored in the Fitbit anyway, unless you do a factory reset. It's just a restart you need to do to get rid of them.
They are also stored on the Fitbit servers.
Best Answer07-05-2019 08:25
07-05-2019 08:25
No it would not
Best Answer07-05-2019 13:22
07-05-2019 13:22
@Cuthbert1 wrote:If I were to restart it would my personal achievements and data be lost also?
Providing you sync to the Fitbit app (which syncs to the Fitbit cloud), you’ll lose nothing.
As a form of encouragement, I had reset my Versa SE once, at least 2-3 weeks ago, and maybe rebooted my iPhone XS once that long ago. Since then, ALL notifications have cleared properly. In fact, I just tried it now to be sure, and I had quite a lot of notifications. I then got the normal notice: “Nothing new here. You’re all caught up”.
Good luck!
Best Answer07-10-2019 12:50
07-10-2019 12:50
Also when your get too many notifications the notifications and call alerts will stop working on the watch and too resolve it you need to clear all the notifications on the phone and the watch and it may start working again. A restart of the watch and phone works for a little while. This issue is on both iPhone and Android with the latest system versions. This makes the watch allot less usefull and it needs to be resolved asap. Also it's super stressfull too never know if notifications works it's almost better to not use the watch at all then. And don't say this issue is only for me I have tried 2 different versas 2 different phones both on iOS and Android and I have tried factory reset on the phones and on the watch.
Best Answer07-14-2019 09:29
07-14-2019 09:29
Hello,
I would like to know when this solution will be delivered. We are reaching more than 6 months that this issue has been identified and no final solution has yet been provided.
It is not quite nice to restart my watch almost every day.
Thanks for replying...
Best regards,
Lucio
07-14-2019 17:21 - last edited on 10-06-2019 13:58 by LiliyaFitbit
Hello as a Fitbit Developer I can tell you this issue is trying to be fixed I see people respond to my post reset you phone and Fitbit for Android and iPhone hold the power button and then fitbit go to settings and then go all the way down then press shut down NOT RESET resetting will delete all data from the Fitbit and setup usually takes a long time so be careful then turn them all back on a go to notifications center in the Fitbit and then press clear all then they will all go away
Thank You
Best Answer07-14-2019 17:22
07-14-2019 17:22
Also Clear as much as you can when you get notifications if you don’t then you will have to reset
Best Answer07-15-2019 02:11
07-15-2019 02:11
Yay! One stuck message for 2 weeks was doing my head in, followed these instructions (I have a lite) and it worked! 😁
Best Answer07-16-2019 08:20
07-16-2019 08:20
Hi. I had a Snapchat message that wouldn’t clear. I just did the restart steps listed for the Versa and now it cleared! Thanks!
Best Answer07-16-2019 15:25
07-16-2019 15:25
No problem Thanks
Best Answer07-27-2019 17:29
07-27-2019 17:29
Is the permanent fix released?
07-27-2019 17:29
07-27-2019 17:29
Not yet being worked on
Best Answer07-29-2019 11:24
07-29-2019 11:24
What is worrying is this problem is still going on and customers were complaining about this issue in December last year. I now have a further problem that I don't receive messages at all unless I uninstall and reinstall the app every 3 or 4 days and I have been told that it's probably my phone as I have a OnePlus 3T and they have only tested it on the OnePlus 1. So I am just about ready to give up on Versa and go to Samsung
07-29-2019 11:31
07-29-2019 11:31
Absolutely right, this is a major issue with a fundanental feature. It's going to be a deal breaker for a lot of people if this doesn't get fixed soon. I came to Fitbit Versa from Apple watch because it supports pretty much all the features I need. With this flaky issue with the notifications though, I'm starting to think I'll need to look for an alternative. The crazy thing is that I can't believe this could be so hard to fix. Fitbit should be all over the fix for this or customers will start going elsewhere.
07-29-2019 11:33
07-29-2019 11:33
I don't understand why they always tell their customers that because the exact same issue is on multiple Android and iPhone phones I have tested.
