Can't connect Klim Pulse Bluetooth Headphone to Versa
Hi
I am looking for some help with trying to connect my Klim Headphones to the Versa. I does not even show when you try and connect to Bluetooth devices.
Are these compatible or will I need to but others??
Moderator edit: Clarified subject and labels
1 REPLY 1
Welcome to the Forums @Gazzer60.
Let me help you figure out what is going on. The first thing I will do is move this thread to the Versa board as I think it is better suited for it.
The first thing I'd recommend is that you try going through the steps listed in this help article. They should definitely help you determine what is going on with your Fitbit.
Let me know if there is anything else that I can help you with.
Lanuza | Community Moderator
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
