12-05-2018
18:02
18:07
EdsonFitbit
12-05-2018
18:02
18:07
EdsonFitbit
Hi Fitbit fam, so I bought these Bluetooth earbuds and I had paired them with my Fitbit to make sure they connect, but I didn’t have any music on it. So when I finally was able to download all my pandora stations to my versa, I go to connect my headphones to enjoy some music and they won’t pair. Keeps saying they can’t find my headphones but my phone connects perfectly fine. Please help!
Moderator edit: added label
12-05-2018 21:15 - edited 12-05-2018 21:22
@CristalN03 I am not sure which earbuds you have. It may be the case of either - either. You may not be able to have them paired with both your phone and Versa. Unless you have Flyer which can support 2 devices. Let's try this:
12-06-2018 08:17
12-06-2018 08:17
@CristalN03 It's great to see you in our Fitbit Community! I'm sorry to hear that your headphones are not pairing properly. I would like to follow up and would like to know if the issue persists or if the issue got resolved after following the great troubleshooting steps that shared my friend @Marrrmaduke.
Looking forward to your response!
12-06-2018 15:32
12-06-2018 15:32
Hey! I have done these steps and it just says no device found.
12-06-2018 20:08
12-06-2018 20:08
@CristalN03 Try rebooting Versa several times by pressing and holding the left and bottom right buttons until Fitbit logo flashes, then pairing with your earbuds again. Could you share the model of your earphones? Also, can Versa see any audio devices? Perhaps you have a bluetooth speaker that you could test with Versa?
12-10-2018 05:26
12-10-2018 05:26
The earbuds that I have are tzumi soundmate by Walmart and it would see the device but not connect to it. Yes it does see other Bluetooth devices just doesn’t connect. When I first tried to pair the versa with my earbuds it worked but only once. Then I tried to after I got music on it and it didn’t work.
12-10-2018 12:18
12-10-2018 12:18
@CristalN03 I think at this point it would be good to test your Versa with other audio Bluetooth device. If it doesnt connect to speakers etc, then I'm afraid you might have to reset it to factory defaults and start from scratch. It's a hassle that's why I would recommend testing other alternatives first.
12-11-2018 04:07
12-11-2018 04:07
@CristalN03 As @Marrrmaduke mentioned, please try other Bluetooth audio earbuds and repeat the connection process.
The factory reset steps that my @Marrrmaduke mentioned above, can be done as follow here: Settings app > About > Factory Reset or Clear User Data. Finally, try connecting your earbuds again.
Let us know how it goes!
