07-19-2018 16:21
07-19-2018 16:21
Can't connect to wifi. Manually entered my wifi. No luck. Went to Starbucks and connected first my phone which worked. Then tried my versa and it wouldn't connect.
Best Answer07-19-2018 18:34
07-19-2018 18:34
Does Starbucks require the user to open a web page and agree to some terms of usage? If so then the tracker, not having a web browser will not be able to connect.
Lets go back to my WiFi, did you get any errors?
Best Answer07-19-2018 19:09
07-19-2018 19:09
It can’t find my home network. I try to enter it manually but I don’t know what the security setting should be. I’ve tried several.
Best Answer07-19-2018 19:45
07-19-2018 19:45
Make sure your phone is connected to your home WiFi before trying to setup the wifiWon the versa.
Best Answer07-19-2018 19:48
07-19-2018 19:48
Done that yesterday
