02-11-2023
10:43
12:06
02-11-2023
10:43
12:06
On my Versa it says I can only have 7 additional exercises, and that to edit I need to go to the Fitbit mobile app. WHERE on it? I have searched unsuccessfully. =(
02-11-2023 10:54 - edited 02-11-2023 10:55
@Winemaven Tap on your profile picture, then your Versa 2 tile. Select Exercise Shortcuts. Your Edit option should be in the upper right of the screen,
Laurie | Maryland
02-11-2023 10:56 - edited 02-11-2023 11:04
Removed. Already answered.
02-11-2023 11:02
02-11-2023 11:02
But it doesn't have an exercise I do: Zumba. How do I add that? It's a tough workout and I want that baby to count! 😃
02-11-2023 11:31 - edited 02-11-2023 17:17
@Winemaven When using a Versa 2, or other Fitbits with the same Exercise Shortcut list, you use the Workout shortcut. You should be able to change the name to Zumba after you are done. You use the Categorize Exercise option when you are looking at the exercise details page in your app.
The Sense 2/Versa 4 added a Dancing shortcut. You can change that to Zumba. But the Sense 2 and Versa 4 have significant limitations compared to the Versa 2. Definitely not a reason to upgrade.
Laurie | Maryland
