05-09-2018 10:04
05-09-2018 10:04
I was checking out different screens and can't get back to the main screen with time, HR, steps and calories burned. Please help. I had the ALTA HR but had trouble seeing the screen so I updated to the versa
05-09-2018 18:30
05-09-2018 18:30
If you are just checking the workout screens, the left button will bring you back to your clockface.
05-09-2018 18:30
05-09-2018 18:30
05-10-2018 13:06
05-10-2018 13:06
06-28-2018 06:07
06-28-2018 06:07
The left button only scrolls through exercise data (distance, speed, calories, etc) and the right buttons either pause or stop the exercise and holding the button goes to a setup function. I cannot seem to get back to the time function from the exercise function without stopping recording the exercise.
05-30-2019 22:29
05-30-2019 22:29
Hello,
Even I encountered the same problem
(On my Fitbit versa lite) I tried pressing the pause button but it didn't work. So I tried pressing the power button a little longer after the quick menu appeared.
This restarted the device and the swim mode was turned off.
Hope this helps and works to you😊
07-14-2019 15:50
07-14-2019 15:50
Versa is not stopping swim exercise like it does cycling and other workouts. I wonder why this is? Why do Versa owners have to press the power button and hold it to end a swimming session.
I finally got out of the session today by pressing several buttons and it ended not even logging the swim session on the dashboard. Yes, Versa is waterproof, however, it is very annoying in that you have to jump through many hoops to stop the swimming session.
