01-08-2024 04:04
01-08-2024 04:04
Hey,
Can anyone help? I've been having syncing problems with my Versa 2, so 'forgot' the device and have tried to add it back. I have done this before and it worked, today I can't get past the four digit code screen. I just have a spinning wheel of doom, saying 'connecting to Fitbit' before it flags up a different code to try.
I've read several threads on this and have tried all the recommended tips and I am still having the same problem.
Any help would be much appreciated. Thanks.
01-09-2024 04:25
01-09-2024 04:25
Hi there, @moogdawg. Thanks for stopping by in the Fitbit Community Forums. It's sad to hear that you cannot set up your Versa 2 despite the steps you've tried so far. I will do my best to help you with this!
To make sure we do things the right way, please confirm that you've tried the steps below in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
If the above has been done correctly, but the issue with the 4 digit code screen persists, I'd suggest performing a factory reset as our last resort. To do so, follow the steps below:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
