09-14-2022 09:40
09-14-2022 09:40
The Versa 2 I’ve had for 15 months decidedly to meltdown yesterday so I purchased a new one. Set up went without a hitch except that I cannot load the sp02 clock face. I had it on my other Versa 2. It says to check to make sure I have the current OS, which everything says I’m currently up to date. Is this no longer a feature of Versa 2?
09-14-2022 10:01 - edited 09-14-2022 11:14
Hello @PixieRoyale
I see your current Fitbit is very new. When you receive a new a Fitbit it needs Firmware updating. That update should arrive between 2-3 days after you set it up. It’s after that update you should be able to have access to all the features the new Fitbit has such as downloading the clock face you want. I hope that makes sense.
😃I hope this provides you the best answer to your question. Please let me know.
09-14-2022 10:03
09-14-2022 10:03
Thanks, that helps a lot.
09-14-2022 10:08
09-14-2022 10:08
Your so very welcome @PixieRoyale 😉 Your question was certainly understandable. I’d be a bit confused as well. Let me know if the update doesn’t arrive after a few days. Please consider marking my previous post as “best answer”. This will help others with a similar question find the answer quickly. Enjoy the rest of your day and Happy Stepping!
