02-15-2022
		02:40
		20:28
		02-15-2022
		02:40
		20:28
Hi all!
I hope some of ur genius minds can help me out.
When i try to make an call by starting google assistance then saying : Call dad, i get a notification saying: Sorry i can not call yet.
Does this mean this function hasnt been enrolled yet in my country? Or is there any other solution for this. I can answer a phone call tho. That's no problem.
Thanks in advance!
Kind regards, Tejjasingh
02-17-2022 03:47 - edited 10-30-2023 04:10
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @Jerzgrl. Welcome on board.
Please bear in mind that you can answer calls directly on your Versa 3, but not make them. For more information, see How do I take on-wrist phone calls with my Fitbit smartwatch?
Hope that helps.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer02-15-2022 04:07
                              02-15-2022 04:07
Hi there, @Tejjasingh. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Note: Alexa and Google Assistant on your Fitbit device are only supported in certain countries. For more information, see fitbit.com/voice. Netherlands is included, though.
Did you recently switched to the Google Assisting while using Alexa? Note that you can have only 1 active voice assistant at a time. To switch to a different voice assistant, first disconnect your active voice assistant. For more information, see How do I disconnect my voice assistant?
Note: The microphone in your watch only turns on when you activate it, for example by opening a voice assistant app. The microphone turns off when the voice assistant responds, when you close the voice assistant, or when your watch’s screen turns off.
If the issue persists, see What should I do if my voice assistant doesn't work on my Fitbit smartwatch?
Hope that helps.
 Best Answer02-16-2022 17:00
02-16-2022 17:00
Same here with me I can answer a call they can always hear me but I cannot make a call
 Best Answer02-17-2022 03:47 - edited 10-30-2023 04:10
Hope that helps.
