10-03-2019
17:13
06:08
10-03-2019
17:13
06:08
Brand New out of box versa 2. Recieve all messages but when I hit open nothing happens, just loops back to home screen. Emails open just fine. Just can't Access any text messages. I have a moto z3. It's not in silent, Fitbit has full permissions. Help
10-04-2019 06:15
10-04-2019 06:15
Hi there @CarlaDCollier, welcome to the Community Forums. Thank you so for making sure all permissions are allow on between your phone and the Fitbit app.
Please note that the Moto Z3 is not yet a supported device by the Fitbit app. You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
However, since your Versa 2 has been working with other notifications, please follow the tips and recommendations provided in the help article: How do I get notifications from my phone on my Fitbit device?
Let me know how the steps go. 😉
11-04-2019 08:01
11-04-2019 08:01
This is happening to me as well, and my Samsung Galaxy 8 is supported.
Why is this happening, and what is the fix? I receive the notifications, but if I it OPEN, it just takes me back to main screen.
11-04-2019 12:17
11-04-2019 12:17
Hello there @MsDebola, welcome on board. Thanks for letting us know about this issue. We’re aware of it and are working to identify a resolution as quickly as possible.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
In the meantime, I'd suggest switching to a clock face that doesn't have a lot of text or graphics on the display. Also, try to clear their notifications more frequently when you receive them.
Please let us know if there's anything we can do to assist you in the meantime.
11-04-2019 12:37
11-04-2019 12:37
1. My texts are always cleared out the moment I receive the notification and attempt to "Open"
2. Out the box, the texts would not open, before changing my face, so this can't possibly be the issue.
Is there anyone in technical support that has an answer?
11-30-2019 20:30
11-30-2019 20:30
I am having the same issue on a Galaxy S8. It won't open any text messages. Had this been fixed?
I was very disappointed that my place of purchase told me they are not allowed to assist in setting it up either.
12-01-2019 03:49
12-01-2019 03:49
This is so annoying, as why have this option if we are unable to use it. I did not have this issue with my Charge 3.
12-26-2019 06:43
12-26-2019 06:43
Has this issue with compatibility with Moto Z3 been resolved yet?
I just received as gift and the same issue with text messages is happening with me.
12-26-2019 06:45
12-26-2019 06:45
12-26-2019 06:48
12-26-2019 06:48
01-03-2020 11:14
01-03-2020 11:14
I have the Samsung S9 plus phone and Versa 2 fitbit and the same is happening with me. Notifies me that I have a text but when I touch open takes me back to home screen.
01-08-2020 11:26 - edited 01-08-2020 14:55
I can’t reply on my message on my Fitbit Versa 2. I have an Apple iPhone 7+. My Fitbit is also out of the box new.
01-08-2020 11:37
01-08-2020 11:37
Myself and my wife got Versa 2 try paring them up with our Huawei Honor 6X wich by the way is on the list of compatible devices and no luck. Called costumer support multiple times done all sorts of possible resets and reboots under their guidance. Still the devices won't sync for more than a few hours at best and after that no more syncing. Really bad experience from a first time costumer here
01-08-2020 11:51
01-08-2020 11:51
So I finally have mine working well. I had to go into my text message app, open settings, then allow for previews. Works great now!
I have a Samsung S9 and a Versa 2.
Good luck.
01-08-2020 19:41
01-08-2020 19:41
I could not find on my S8 "allow previews" BUT, I did play around with some permissions etc on the Fitbit app and my message app. I cannot say for sure what worked, but it did!!! All because of your tip, so THANK YOU!!
01-13-2020 14:14
01-13-2020 14:14
I want to throw it away...I need to open my text meesages.Any resolve??
01-14-2020 06:07
01-14-2020 06:07
I followed Charity's advice, and now mine is working. First make sure your phone is compatible, and them make sure ALL your permissions are turned on, check your phone settings as well as your settings in the Fitbit app. I wish I could pinpoint what exactly I did to make mine work, but I can't. I just remember going in and checking everything. Oh, and I allowed the app to run in the background, where I previously had it turned off.
I hope you get it to work soon!
01-16-2020 15:31
01-16-2020 15:31
Can you tell us what you did? I have a Versa 2 and Note 10+
01-16-2020 18:05
01-16-2020 18:05
Hey!
Unfortunately I can't pinpoint what exactly made it work, as I had alot of things turned off, and had apps sleeping in the background. I started with the Fitbit app permissions, and made sure they were all turned on. And in the notifications, I selected Messages
I also went to my phone settings, as I had it set to not run in the background..I turned it back on.
Was really frustrating but SOMETHING finally clicked and now it's working. Hope you have some luck with yours!
01-16-2020 19:03
01-16-2020 19:03
Is Samsung Note 10+ a supported device?
