03-18-2019
09:38
08:41
AlvaroFitbit
03-18-2019
09:38
08:41
AlvaroFitbit
I recently bought the Samsung Galaxy s10 and I cannot pair it with my Fitbit versa. I read somewhere it is not compatible with this phone yet. Is this correct? Will it be compatible soon..?
07-22-2019 16:36
07-22-2019 16:36
Hello there
There are two places on Versa that can effect if the notificztions come thru. One place is thru the settings making sure you have selected on and also make sure vibrations are on.
The other place to access is by pressing and holding the button on the left side of the watch..Make sure notifications are set to on there as well. Not sure why ...but sometimes this flips to off when you are trying so many things to make this work
Best Answer07-22-2019 17:18
07-22-2019 17:18
Fitbit is still trying to catch up to Android 9.0 Pie and Samsung Galaxy S10 series. I downloaded latest fitbit.com/setup and am syncing to computer rather than phone. Unclear when sync problem to phone will be solved. Customer Service said there are problems with the phone, not just Android 9.0. Looks like we are all going to have to wait -- or use computer in interim.
Best Answer07-22-2019 18:34
07-22-2019 18:34
Hello there,
Sorry to hear you are still having an issue. I purchased my Versa in July 2018 and Galaxy S10 plus in March 2019..I initially had problems but after discovering the Smart Things app in the Galaxy S10 it has been nothing but smooth sailing. You have to have that running in the background and I dont think Fitbit is aware you have go thru this app to make the notifications work
Every app that I have selected to receive notification on my phone syncs and vibrates perfectly to the Versa. If you search this issue in the community you will see the steps to success others have experienced. I dont think the Fitbit set up instructions are going to mention an app designed by Samsung is required to make this work...but it does..
Best Answer08-07-2019 13:35
08-07-2019 13:35
I just purchased the galaxy 10 & found out on forums that this phone is not compatible with Fitbit. Those posts were from March! When will this be resolved?? I can't access my phone during work, so those notifications were vital. IF this won't be resolved then I would like to know so that I can purchase a watch that is compatible.
Best Answer08-07-2019 13:39
08-07-2019 13:39
It will work, it's a real pain in the a$$, but it will work if you follow the steps provided above.
Best Answer08-07-2019 13:43
08-07-2019 13:43
Best Answer08-07-2019 13:45
08-07-2019 13:45
Best Answer08-07-2019 13:54
08-07-2019 13:54
08-07-2019 15:36
08-07-2019 15:36
Please look at my second post about this...You have to use the Smart Things app that is loaded on the s10...Not sure if Fitbit is mentioning this app has to run in the background to support the watch but if they aren't their resolution. Is never going to work...
Best Answer08-28-2019 19:48 - edited 08-28-2019 20:03
-Factory reset your Versa.
-Keep it away from your phone overnight.
-Unpair your Versa the next day on bluetooth on your phone.
-Uninstall fitbit app and then reinstall it.
- Turn Versa on and set up through app.
After troubleshooting for over three months THIS WORKS! Fitbit customer support didn't even recommend this. Goodluck guys! Upvote this so others see it.
09-14-2019 10:41
09-14-2019 10:41
I have done all of these steps and it's still not working.
Best Answer09-14-2019 12:45
09-14-2019 12:45
Look at all of my posts. . Make sure you are using regular Versa and the Smart Things App provided by the s10 is running in the background .and make sure when you press and hold the button on the left side of the watch notifications are on
Best Answer09-14-2019 15:08
09-14-2019 15:08
Ma'am I have done all of those things.
Best Answer09-15-2019 05:01
09-15-2019 05:01
Since we know this works, then something is amiss, and each step you have followed needs to be examined in detail. Can you see the Versa listed under the Bluetooth connections on your phone and listed under "other" devices in the Smart Things app? If done correctly the Smart Things app will always appear between the brightness slide and the pane for your notifications .
Best Answer09-15-2019 07:41
09-15-2019 07:41
I just did what you suggested re: Smart Things. It shows my versa paired but still the fitbit app shows no device found. I've had thus S10PLUS since March with no problems until about a week ago. Now it won't sync at all.
Best Answer09-16-2019 13:32
09-16-2019 13:32
I can't pair my versa with my s10plus either. The s10plus has been out since March 2019. That's 6 months and it's a hit and miss situation wth the Fitbit app. Versa no longer syncs. I'm looking at the Samsung Galaxy 2 smartwatch. Fitbit Support via this site as well as Twitter and Facebook just gives me the runaround WHEN they respond. I love my Versa, bought 3 more for my kids. Not anymore!
Best Answer09-16-2019 14:28
09-16-2019 14:28
I certainly hear your frustrated. I also have the s10 plus. So we need to examine in detail where the problem is for you. So to begin with make sure that everything within the Fitbit app is selected correctly.
1) On the dashboard pane path is Apps/All Apps.. and just select all of them for notification. You can go back and deselect the ones you don't want later,
2) Back to the dashboard on the landing page make sure all day sync is selected.
3)Then scroll down further under General select and turn on Calls.
4)Under Text Messages make sure the app you use for text messages is selected.
5)Under email make sure the app you use for email is selected.
(One thing to note is that you must make sure the specific app you use is the one you have selected. So if you have multiple email apps, text or even a phone app and the wrong one is selected you won't get the notifications. )
6)Back to the dashboard under General/Notifications/App Notifications. select all again for now and then you can go back later to deselect
7)Now out to the watch itself Go to settings and make sure vibrate and notifications are set to on in the settings but also make sure that when you push the button on the left side of the watch the notifications are on there also
I have "lost notifications" also and usually when I turn the Bluetooth on and off they come back.
8)To pair go to connections in the phone and make sure Versa is paired there with bluetooth
9)Then go to the Smart Things app click the 3 line menu at the top left and then select "All devices" search for and pair Versa there also
When it shows paired in the Smart Things App and also in the phone it should work. When done correctly you will see "Smart Things" running at the top of your notification pane on the front of the phone right underneath the brightness slide bar . If not turn your Bluetooth on and off .
Hope this helps.Good luck!
Best Answer09-16-2019 16:29 - edited 09-17-2019 04:12
Thanks for your help.... that didn't work. I give up. It's time for a new smartwatch hopefully with a more dependable company 😞
Best Answer09-17-2019 17:49
09-17-2019 17:49
So.... these are the steps I've taken in order for my Versa to sync with my s10plus
1.Turn off and on phone's bluetooth and tap Versa to connect
2.Tap the screen on my versa, go to settings, scroll to bluetooth
3.Tap versa bluetooth until it shows OFF, ON, PAIR. 4.Choose pair.
It will then sync with my phone. I have to do this everytime in order for it to sync because the Versa bluetooth option reverts to OFF.
I realize it may be for music only, so I'm not sure why it's reverting to OFF?
Best Answer09-17-2019 19:19
09-17-2019 19:19
So you can view your text messages on your versa 2 with S10 phone???
