Can't read text messages on my versa
ANSWERED
My versa will tell me I have a text but I can't read it on the versa. Any help?
46 REPLIES 46
Not sure if you got an answer, but I finally figured it out: you have to change the message settings to allow message previews on your phone. Previously, my phone's (Galaxy S9+) setting only said "New Message" and did not show the name/message preview. Once I changed that to "show preview" in my messaging/notifications settings, it shows up just fine on my watch, contact name and text. Hope this helps!
I did all of the above  I  can't get my text messages to display...only notifications that I have a message.  I have Galaxy S8+
How did you get yours to work
@Buttas  If you aren't seeing the content of the message the problem is likely that you need to go into the settings for your phone and set the Notifications to "Show On Lock Screen" for your texting app and any other message apps you like to use.  Give that a try and let us know what happens.
Kathy | USA
Versa SE, Charge 2, Samsung Galaxy S10+
I got it!!!!
Thanks
For a samsung s8+ If you want to read the messages on the versa but not your lock screen i did this by going to my settings, notifications, messages.  Make sure this is on to allow notifications. For both general and new notifications i went in and turned it on, went to on lock screen and chose hide content.  Then i went to more settings in app and turned on show messages on lock screen and in pop ups.  Now the lock screen and pop ups show i have a message but says content hidden.  But on my versa i can read the message.
You need the help of the SMS manager software. With it, you can directly read you messages on computer by using your keyboards via a simple USB cable.
Got it fixed ages ago. Thanks
With fond regards,
Gail
I have my Versa working now ..... but I will keep this message for future
reference.
thanks,
I can receive phone calls on my Versa and other updates but I can’t receive text messages
How do I read text messages on my versa lite
I just did this!!  Fingers crossed its worked.. waiting for someone to message me now to test!
I am not abel  to read my texts on my versa fitbit  watch
@SunsetRunner wrote:
What phone are you using? Samsung Note 9
Samsung Note 9
Samsung Note 9
@Lpickett50  Did you read through this thread and try the fixes posted? If you are getting notification that you have a new message but can't read the content of the message, then you need to go into the Settings on your phone and set Notifications to appear on your Lock Screen. If you are getting no notification at all, then your problem is something else. You have not provided much information to go on.
Kathy | USA
I can't read my texts I tried doing what yu said on the replys
no I do not even see the fit bit at all on it, I am so confused at this point. trying my best, I eel like taking the watch back
@razerf15 wrote:
No problem at all. Try checking one more thing. Go to Lockscreen and Security in settings. Scroll down to Notification Access. Is Fitbit Notification Service enabled?
I can not get it too work
so are you saying I should be able to read my texts now?
@Rbromero wrote:
I just checked that too and yes fitbit has all permissions.
so how do I read my texts on my phone.I am not trying to be a pest. I just want to know what I should do and do it right. you have been awesome
How do I do that
@razerf15 wrote:
Sorry, I guess you'll have to just join the cool people with Textra 😁
please tell me how I do that. I really like you helping me..
This is old. I got it fixed. Thank you.
With fond regards,
. Gail
how do I start using textra
