08-28-2022 09:57 - edited 08-28-2022 17:05
My battery was draining too quicky and the forums suggested a factory reset. Now, I can't get reconnected. So far I've restarted my Versa 2 multiple times, logged out of the app, uninstalled and reinstalled the app. Restarted the phone. Removed all fitbits from the Bluetooth on my phone. Turned the Bluetooth off and on multiple times. Checked my version of android. I go through the start up process but after the "Found It" screen it goes to "Not Working?" and offers tips all of which I've performed multiple times. I've followed all the steps from Marrefitbit on this thread https://community.fitbit.com/t5/Other-Charge-Trackers/Can-t-find-the-4-digit-code/td-p/2122410.
Okay, Finally got the four digit code. It took 4 tries but got as far as adding to the wifi when it froze on the fitbit logo. App says "Looking for Versa 2. It timed out and I"m starting again. Very frustrating
08-28-2022 11:18
08-28-2022 11:18
Hello @Martanelso
I’m hoping I can help. It sounds like your doing a lot of troubleshooting steps to try and get your Versa 2 set back up again after you factory reset your Versa 2.
Here is how you set up your Versa 2 as a new device. Please follow each step carefully:
🤞 I hope this helps. Please let me know
Best Answer08-28-2022 17:02
08-28-2022 17:02
I've tried multiple times, still with no success. Occasionally I get as far as signing into my wifi but then it always fails. Most times I can't even get that far.
08-28-2022 17:33
08-28-2022 17:33
Gosh @Martanelso I’m sorry your running into so much trouble 🙁
Maybe this like will help your Wi-Fi issue: https://help.fitbit.com/articles/en_US/Help_article/1872.htm#:~:text=to%20Wi%2DFi%3F-,Try%20setting%....
This article will help as well: https://help.fitbit.com/articles/en_US/Help_article/2249.htm
🤞 I’m truly hoping this helps. Please let me know
Best Answer08-28-2022 18:14
08-28-2022 18:14
The Wifi is working properly. The process seems to hang up at random points in the process. 90% of the time it hangs up right after the "Found It" screen and the "Not Working?" screen appears. Very occasionally I'll get the chance to put in the 4 digit code but I never get past setting up the wifi
Best Answer08-29-2022 04:55
09-02-2022 18:50
09-02-2022 18:50
I tried everything. Fitbit support gave me a 35% off discount. I'm disappointed that the lifespan of this product only slightly outlasts the warranty. I'll try once more with a Fitbit product but the next time this happens I'll need to shop around again which saddens me because I love my Fitbit.
