10-22-2022
07:18
17:02
10-22-2022
07:18
17:02
How can I remove a card from a fitbit pay account if it doesn't show up in my wallet?
10-24-2022 03:36 - edited 08-04-2023 04:31
@Gsv54 Thanks for the details provided in your previous post.
Regarding your inquiry, please check if your card works with Fitbit Pay by clicking here Supported Banks and Transit List.
In addition to the steps you've done so far, please try the following:
10-22-2022 10:42 - edited 10-12-2024 12:35
Hello there, @Gsv54. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Fitbit Pay.
As per the description of your post it seems like the card was already removed. Note After you delete a card from Fitbit Pay, the card is removed from the Wallet and you can no longer use it to make payments with your device. To make sure you did remove it correctly, verify the following steps:
For more information, see What should I know about Fitbit Pay?
Hope that helps.
10-22-2022 23:09
10-22-2022 23:09
I can't remove the card from the wallet because the wallet is empty. But when I try to add a card to the wallet, I get a message that it has already been added to the fitbay pay account. The bank told me that they support fitbit pay. But does fitbit pay work with Belarusian banks? Perhaps the problem is this.
