12-22-2022
05:41
06:10
AndreaFitbit
12-22-2022
05:41
06:10
AndreaFitbit
When I hold the buttons for 10-seconds to restart my Versa3, the Fitbit logo does not appear; message shows "setup voice assistant." Many problems now with device : No sleep scores, missing metrics, plus bad weather info. I have contacted Support 4times; they resolved other problems I was having but not those I just listed. Wondering if I should just trash my Versa3?
Moderator edit: format.
12-23-2022
05:54
07:43
12-23-2022
05:54
07:43
Hi @fincherb - your watch may be fine, it can be just a configuration problem.
The restart isn't working because you are long pressing the button which takes you to voice assistant. This means that you didn't hold the button for 10 seconds, or hold it properly.
It would also seem your watch is not syncing properly, try logout of the Fitbit App and a phone restart.
If you are having problems with the button, in the watch Settings menu at the bottom do a Shutdown. Wait at least 10 seconds before placing on charge to restart it and charge it.
When both have been restarted you may be working again. In case not see
Why won't my Fitbit device sync?
Note: In watch settings, Shortcuts, you can turn off long press
Also try turning the screen on and off with the button to ensure you have the knack for using the button before using it to do a restart another time.
12-23-2022
05:54
07:43
12-23-2022
05:54
07:43
12-29-2022 05:31
12-29-2022 05:31
Thank you so much for the info but still having issues. Contacting support by phone!
