01-07-2019 18:56
01-07-2019 18:56
The water log isn’t showing on my Fitbit Versa. I can see it in the app, just not on the actual Fitbit. I already checked to make sure I had it checked for tracking in settings, but it is missing from that list also.
01-07-2019 19:01 - edited 01-07-2019 19:05
Same problem here. The today app is not showing water or sleep. The new firmware was supposed to show this and calories but I have none. I tried hard reset and updated the device twice without luck.
01-07-2019 19:03
01-07-2019 19:03
Hi. I just had the same problem. Restarted my Versa and it still wasn't there. Neither where some of the other options. However a few minutes later the missing items returned. I also fully closed the Fitbit app and then re-opened it.. Don't know if that helped or not.
01-07-2019 19:17 - edited 01-07-2019 19:20
@ Lisa It worked!!! I completely closed the app and restarted my Iphone and Versa. A few minutes later I have all the stats for the first time since the new firmware launched last year! You solved my problem. Thank you so much for your help
01-07-2019 19:34
01-07-2019 20:38
01-07-2019 20:38
@nhlisa It worked for me as well! Thank you so much!
01-07-2019 20:42
