02-20-2024 05:42
02-20-2024 05:42
Since a day I can't select a workout or walk on my fitbit.
When I select "Exercise" it goes back to .."exercise" not able to select further.
As a result the work-out doesn't show on my stats.
I already tried shutting down and restart.
Any idea?
02-20-2024 09:59
02-20-2024 09:59
@ketomama1 , a warm welcome to the Community! Thank you for your message and efforts.
I assume that you tried the restart with the help of the menu on the settings app on the Versa 3.
If you haven't done so, charge the Versa 3 at least for 30 minutes.
Remove it from the charging cable.
Press and hold the button for 8 seconds.
When you see the Fitbit logo release the button.
The Versa 3 should restart again.
03-21-2024 10:00
03-21-2024 10:00
I've tried that several times already. 😕
03-21-2024 10:20
03-21-2024 10:20
@ketomama1 , Thank you for your reply and confirmation.
In that case I suggest you give our team a call or chat with them, so that they can investigate your case further.
They'll be more than glad to assist you further.
Here is our contact info
