01-08-2024
11:57
04:06
01-08-2024
11:57
04:06
When trying to connect with spotify I go into settings to connect with my account. The problem is that there is nothing but a white screen when opening the settings in the fitbit app. Im on a huawei phone if that helps!
01-08-2024 20:32
01-08-2024 20:32
Hi @MeistrooVersa2 - there are bugs in the new V4 Fitbit App and the white page is one of them. There is no fix.
However try setting up the built-in Music controls instead which allows you to control any music playing on your phone and adjust the volume without stopping what you are using on the watch.
01-12-2024 06:03
01-12-2024 06:03
So you tell me the white screen will never be fixed?
