01-22-2024
00:34
05:03
01-22-2024
00:34
05:03
I cannot connect my phone to my watch versa 3.i forgot my 4 digit passcode.what will i do to connect?
Update: Please help me for this problem
01-22-2024 02:04
01-22-2024 02:04
Hi @laarni47 - you may be able to reset it, see How do I use the device lock on my Fitbit device?
01-22-2024 06:43
01-22-2024 06:43
Hi there, @laarni47. Thanks for stopping by in the Fitbit Community Forums. It's sad to hear that you cannot connect your Versa 3. We'll be glad to help you!
Have you tried the steps recommended by @Guy_?
As per the description of your post, it seems like your Versa 2 is no longer paired to your phone. That would explain why the options are no longer available in the Fitbit app. With that being said, the only way we can bring your Versa 2 back is by performing a factory reset. However, please take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
To perform a factory reset, please follow the steps below in the order listed:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
