05-19-2023
19:46
10:27
05-19-2023
19:46
10:27
Hi. My Versa 3 was having trouble charging and sometimes swiping between the screens became inconsistent. In my frustration I decided to remove my device from my account to reboot. Unfortunately now when I try to add the device back on I sometimes get to the point where my phone wants the 4 digit code my watch is supposed to provide but it only brings up the green login screen with no code. When I follow the troubleshooting process it sometimes Bluetooths to my watch and sometimes not. It is another issue I have. Does anyone know how I can get my phone to pair again. I have tried the Live Chat but may have not have got issue across very well. Much appreciated
05-20-2023 06:25
05-20-2023 06:25
Check your phone's bluetooth connections to make sure you really did remove the fitbit device.
Yes, it is possible to pair a device a 2nd time by adding a new device.
If you have removed it from your account, the time that shows on Fitbit device is basically irrelevant.
I just know that sometimes it takes several tries to add new device. It helps to remove all other bluetooth devices far away.
I'm not sure I'm familiar with green login screen of Fitbit but that's probably irrelevant.
Best Answer05-19-2023 19:57
05-19-2023 19:57
How did you 'remove your device from your account'?
Best Answer05-19-2023 23:37
05-19-2023 23:37
Best Answer05-19-2023 23:43 - edited 05-19-2023 23:47
Hi. Is it possible to pair a device a second time if going through the process of adding a new device eg not a new watch. Further information is that my watch has lost 18 minutes of time. My watch shows 4:27 but my phone shows 4.45. In case this indicates something too
05-20-2023 06:25
05-20-2023 06:25
Best Answer05-20-2023 19:12
05-20-2023 19:12
Best Answer05-20-2023 19:19 - edited 05-20-2023 19:19
Great. What did it? or just kept trying?
Best Answer05-21-2023 21:45
05-21-2023 21:45
05-22-2023 06:34 - edited 05-22-2023 06:36
Thanks for bothering to reply. I guess it sometimes does get confused the more bluetooth devices it sees, though would be nice if it didn't.
