06-15-2021
16:08
13:40
YojanaFitbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-15-2021
16:08
13:40
YojanaFitbit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
Hi,
I recently bought a 2nd hand fitbit versa and tried to pair it to my phone (samsung note 20 ultra with the latest software update). I made sure that all other Bluetooth devices were disconnected from my phone, I checked to see if the app had the battery optimisation option on (and turned it off) and the app never seems to find it when I try to set up a new device.
I believe I bought a counterfeit charger. Do you think that might be the issue for the fitbit not being found by the app? (I know it sounds absurd but it is the only thing I can think of).
I tried charging the fitbit completely and doing the setup while the watch was not plugged and also tried it when plugged and it made no difference whatsoever.
I need help setting it up for the first time please!
Many thanks
06-16-2021 13:39 - edited 06-16-2021 13:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi there, @LorenaPelea. Welcome to the Community Forums.
Thanks for trying to troubleshoot the issue with your Versa before reaching out. I understand where your concern is coming from, but I think that if you can see that your Versa is charging it should be able to connect properly.
If you're continue having issues to set up your Versa, please see Why can't I set up my Fitbit device? You can also check more details with Customer Support.
Hope that helps.
