01-28-2021
08:40
08:46
01-28-2021
08:40
08:46
I've spent all afternoon and evening and this morning trying to get my Versa 2 added back onto my Android phone. Yesterday it stopped syncing to my phone so I did everything suggested, turn phone off and on (NUMEROUS TIMES), shut down fitbit (NUMEROUS TIMES) and logged out of my fitbit account. I also uninstalled my fitbit app and installed it (NUMEROUS TIMES). Then it was suggested that you remove the device from your account and reinstall it! WELL I CAN'T! I also turned Bluetooth on and off (NUMEROUS TIMES).
03-01-2021 05:33
03-01-2021 05:33
I just continued every day to reinstall and pair and it worked. It was beyond frustrating. I have all my reminders, and receive my emails and calls on my fitbit so when it wasn't working I was lost! I did hear the Fitbit was having some type of issue that was causing the problem.
Best Answer03-01-2021 05:44
03-01-2021 05:44
Best Answer03-01-2021 05:46
03-01-2021 05:46
Good luck. If you can't get it soon, I'd be sending it back for a new one! There shouldn't be that many problems with the device.
Best Answer03-01-2021 06:38
03-01-2021 06:38
04-13-2021 14:47
04-13-2021 14:47
Omg! I am having this SAME issue! I've tried everything numerous times! So frustrated! Any update from fitbit??
Best Answer04-13-2021 14:48
04-13-2021 14:48
Any update on the Android issue? I am so frustrated!
