04-24-2020 01:15 - last edited on 04-27-2020 20:01 by LiliyaFitbit
Is there any update for the many of us who are unable to use the swipe function? Lots of us have tried restart and factory reset to no avail. Any help very much appreciated.
04-24-2020 01:20
04-24-2020 01:20
It seems to me that if a restart / reset is not working then it's likely a hardware issue and we need to contact customer support to discuss replacement options.
04-24-2020 02:31
04-24-2020 02:31
I am having the same problem. I received the versa2 via The telegraph in February. It worked fine until the last week when it keeps turning on and off, resetting and can’t swipe. Very annoying
04-24-2020 03:28
04-24-2020 03:28
Mine started doing this a couple of weeks ago. It will restart on it's own and if the screen is locked (will not swipe) I have to manually restart it. Getting very tired of it as you never know when it will not swipe. Also during exercise tracking, it will sometimes restart and kill my tracking. Did a factory reset but no change. Hopefully someone has an answer.
04-24-2020 04:42
04-24-2020 04:42
04-26-2020 09:52
04-26-2020 09:52
04-26-2020 10:14
04-26-2020 10:14
So, this happened last week and spoke to customer support and they’re sending me a another one as it’s still under warranty (purchased 6 months ago). In the meantime, I had been trying to use my original Versa and it went from not being able to swipe (soft-reset), then it worked fine for half a day, then unable to swipe again, so did another soft-reset and now the screen shows the Fitbit logo for a 6 seconds then goes blank for 6 seconds at it continues to cycle over and over. The left button does nothing, so I believe it’s officially dead. So frustrating because it worked beautifully up until I woke up last week to find the screen unresponsive.
04-26-2020 23:50
04-26-2020 23:50
04-26-2020 23:52
04-26-2020 23:52
