11-26-2018 21:58
11-26-2018 21:58
I had the charge HR and decided to upgrade to the Versa because i wanted to be able to listen to music.I haven't been able to transfer music to my versa for the past three months or so and i have tried EVERYTHING. i have reset the versa three times in a row, talked to customer support via chat, all they do is say " we'll escalate and send an email" and that does NOTHING. I've done that three times. I mean seriously, a $200 watch and it doesn't do what its suppose to?! It just sits there saying waiting to connect, the Bluetooth is off, wifi is connected and four hours later (literally) nothing can be transferred to the watch. Fitbit either needs to send me a brand new watch or send me my $200 back.I should of gotten the apple watch, at least i'd be able to put music on it with no troubles.
11-26-2018 22:01
11-26-2018 22:01
@reesiepoo hmm this may sound silly but have you tried putting all involved devices near the router? And by near, I mean almost on top... Alternatively I would try a different wifi network...
11-26-2018 22:05
11-26-2018 22:05
You seriously have to do all that just to transfer music?! you know, i'd rather just use my ipod and throw this thing in the trash. the only thing its good for at this point is tracking my sleep, which i could've done with the Charge HR. Like i said, Fitbit needs to either send me a new watch the work properly or send me $200.
You choose
11-26-2018 22:09
11-26-2018 22:09
@reesiepoo Well, I understand your frustration, nevertheless, before sending you anything, Fitbit will ask you to cover all troubleshooting steps. This is one of them.
11-26-2018 22:11
11-26-2018 22:11
I have reset my watch constantly, spoken with fitbit CS four times, they escalated, sent email, NOTHING, and yes i tried that, nothing.. Send me a new watch or send me $200
11-26-2018 22:12
11-26-2018 22:12
I've HAD IT with this thing not working the way it should.
11-28-2018 14:28
11-28-2018 14:28
Just so you know, that was not a solution.
11-28-2018 14:42 - edited 11-28-2018 14:43
@reesiepoo wrote:Just so you know, that was not a solution.
@reesiepoo Then, why did you mark it as a solution? I am afraid I am unable to help.
11-28-2018 14:52
11-28-2018 14:52
I had the charge HR and decided to upgrade to the Versa because i wanted to be able to listen to music.I haven't been able to transfer music to my versa for the past three months or so and i have tried EVERYTHING. i have reset the versa three times in a row, talked to customer support via chat, all they do is say " we'll escalate and send an email" and that does NOTHING. I've done that three times. I mean seriously, a $200 watch and it doesn't do what its suppose to?! It just sits there saying waiting to connect, the Bluetooth is off, wifi is connected and four hours later (literally) nothing can be transferred to the watch. i got it to work the other night but turning ON the Bluetooth on both my phone and my laptop after resetting my watch for the 5th time in 3months, but when I tried to sync music again tonight, i STILL was not able to do so. i shouldn't have to reset my watch every time I want to sync a new or update a playlist to my watch. especially when i was working fine the first two months i purchased it.
I spoke with Fitbit customer support on the phone. Apparently, this is a known issue but there is NO SOLUTION at this time. We, who are experiencing this issue, are expected to wait until they can find a solution. $200 down the drain. I have to go back to using my iPod and listening to Bluetooth headphones when i work out
