Can't turn it on
My fitbit vera did not show the screen so I could not turn off my alarm. I just tried to turn it off and turn it on but I failed to turn it on.
I charged it last night.
I loved it. Please give me some advices.
8 REPLIES 8
@_mimosarah Try rebooting your tracker by pressing and holding the left and bottom right buttons until Fitbit logo appears (for Versa Lite - press the back button for 10 seconds).
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
I did. But it does not turn it on.
I will try one more time.Thank you anyway.
@_mimosarah So it's charged and the screen is black. Are the sensor lights blinking? Is it still syncing?
Yes
The sensors are not blinking. It fully charged. So I do not know what happen it there.
@_mimosarah that could mean either it's dead dead or not charged. Wipe the ports with some alcohol and try charging from various sources (outlet or usb port on your computer) for several hours. Then attempt reboot. If this not help and the lights are still not blinking and tracker is not syncing, press and hold all buttons for up to 3 minutes or until logo flashes. If this does not help, I'm afraid you will have to reach out to Customer Support as you might require a replacement.
Thank you.
@_mimosarah Let me know how it goes.
Hi, it still has same problem. I think I shoyld contact to customer service.
