Can't unlock Fitbit Versa
ANSWERED
Hi, my Versa wasn’t syncing so I went to delete it off my app and add it again. When I went to do this after the Bluetooth connection it asks for the code on my Versa. My Versa says unlock with phone but as it’s not linked anymore it won’t unlock. I’ve tried restarting it, restarting phone, app everything but I can’t get it to work! Help!
1 BEST ANSWER
Accepted Solutions
Hi @BT001 Oh dear! Try the Semi factory reset below, but if that doesnt help younwill need to contact Support.
SEMI FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up.  Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Community Council Member
Helen | Western Australia
1 REPLY 1
