06-02-2025 14:36
06-02-2025 14:36
I’m having trouble with my Fitbit Versa 3. The watch keeps displaying "Unlock with your phone", and when I try to unlock it through my phone, I get an "Error" message.
I have already tried the following steps:
Removed the watch from my Fitbit account
Restarted both phone and watch
Turned Bluetooth off and on
Uninstalled and reinstalled the Fitbit app
Attempted a factory reset
None of these steps have worked.
It seems like the watch may still be locked due to a previous Fitbit Pay setup or security feature.
Could you please help me unlock the device or reset it so I can set it up again?
Kind regards
06-02-2025 18:09
06-02-2025 18:09
Hello @SThe, thanks a lot for joining the Fitbit Community!
I really appreciate the time you've invested describing the steps you've already taken.
I can definitely understand why you've done those steps. Unfortunately, unpairing the device from the account is not as recommendable as you probably think.
The device cannot connect with your phone once it gets locked and unpaired. This time, a manual factory reset will be needed. Please follow the steps below:
Once you have done that, try setting up your device once again.
Best Answer06-02-2025 23:30
06-02-2025 23:30
Hi again
I have tried that around 10 times without any luck.
Any other suggestions? 🙂
S
Best Answer06-03-2025 19:10
06-03-2025 19:10
Hi @SThe, thanks for coming back!
Let's try making sure that you remove the device from your phone's Bluetooth connection. Also, try restarting the device and make sure there isn't any pending update for the Fitbit app.
Please note that these are just steps to exhaust any possible way to solve this, but actually, if your watch isn't pairing after the factory reset, there isn't much more we can do 🙁.
If that doesn't work either, please feel free to contact our support team by filling this form out.
