Can't unlock my Versa 2 with my phone
I have a message that says "Unlock With iPhone" but even when I go in the app and try and change the code, it doesn't work. The watch isn't on the app anymore so I'm trying to reset it from the watch.
1 REPLY 1
Hi there @carohamp13, welcome to the Community Forums. Thanks for the details provided in your post, I'll be glad to help you to unlock your Versa 2. I appreciate you've taken the time to fix this issue prior to posting here. Nice way to go!
I recommend doing a factory reset directly from your Versa 2:
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
    1. Release the button briefly (for less than 2 seconds).
    2. Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
