11-25-2022
20:59
07:16
11-25-2022
20:59
07:16
Hello ... my versa 2 is disconnected from my phone .. now my phone is asking a code from the watch to unlock the devide and my watch asking to unlock from the phone .. now i cant even hard reset the watch by pressing the keys .. is there any other ways for me to hard reset the watch.. tq
11-26-2022 07:17 - edited 08-17-2023 04:19
Hi there, @RaywindranRaj. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. @Guy_ Thank you so much for your help!
As per the description of your post, it seems that your Versa 2 is no longer connected to your phone's Bluetooth. With that being said and in order to unlock the watch now that it's no longer paired to your phone, I suggest to perform a factory reset by following these steps:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
11-26-2022 01:42 - edited 11-26-2022 01:44
Hi @RaywindranRaj - it seems there is just a syncing problem and it may not be necessary to factory reset to resolve that. In some case a factory reset will destroy the watch so only should be done as a very last resort.
As a first attempt try logout of the Fitbit App and restart the phone and watch How do I restart my Fitbit device?
When you log back in to the app, don't close it but return to the phone home screen. A sync pop up should appear, if it's not already synced, click on this and wait for the watch pair and link prompts and sync.
This may be enough to get it working again.
Here is some info which may also help How do I use the device lock on my Fitbit device?
12-20-2022 15:15
12-20-2022 15:15
Doesn't work, just says data not cleared sync & try again
12-23-2022 13:47
12-23-2022 13:47
Hi there, @SpartanBuddha. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Fitbit device.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with the Fitbit device, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
12-28-2022 01:30
12-28-2022 01:30
Hold the back button for about 8 seconds. When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds). Hold the button again until they feel a second, longer vibration, which indicates the factory reset.
Regards,
Will
12-28-2022 01:58
12-28-2022 01:58
HI @willjoe - who are you writing your post to? It would help if you mentioned the name of the person to whom you are replying. You can enter the "@" sign and select the name.
Did you check the other posts in this topic before posting, as the information you have provided has been posted already?
