06-03-2023
06:46
08:54
06-03-2023
06:46
08:54
Hello ... my versa 2 is disconnected from my phone and every time I get the message in watch for unlock with your phone .. now i cant even hard reset the watch by pressing the keys .. is there any other ways for me to hard reset?
Moderator edit: clarified subject.
06-03-2023 08:57
06-03-2023 08:57
Hi there, @MahendraMS. Welcome to the Fitbit Community Forums. Thanks for following the recommendations provided by @JohnnyRow.
In order to unlock the watch now that it's no longer paired to your phone, I suggest to perform a factory reset by following these steps:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Best Answer06-03-2023 07:58
06-03-2023 07:58
Here's about unlocking with phone, but it has nothing to do with being disconnected from phone so don't know if it's what you want:
Best Answer06-03-2023 08:11
06-03-2023 08:11
Hello Johnny,
Thanks for your reply. Unfortunately I am not able to find the device lock option in my phone app while my watch was in sync with the app.
I tried reinstalling the latest update from playstore but no luck!
06-03-2023 08:57
06-03-2023 08:57
