01-18-2024
08:38
04:12
01-18-2024
08:38
04:12
Versa 2 locked , and can't be unlocked with phone since device lock option is absent in settings
01-20-2024 04:16
01-20-2024 04:16
Hi there, @Northernsailor. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post, I'll be glad to help you to unlock your Versa 2.
As per the description of your post, it seems like your Versa 2 is no longer paired to your phone. That would explain why the options are no longer available in the Fitbit app. With that being said, the only way we can bring your Versa 2 back is by performing a factory reset. However, please take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
To perform a factory reset, please follow the steps below in the order listed:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
01-20-2024 04:16
01-20-2024 04:16
01-20-2024 19:13
01-20-2024 19:13
Thanks a ton , it did work !
01-21-2024 02:24
01-21-2024 02:24
@Northernsailor Awesome! I'm glad to hear that the steps recommended did the trick!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
