08-13-2024
06:01
09:36
08-13-2024
06:01
09:36
My Fitbit versa two has an incorrect time and will not do a factory reset. I get a message that says unlock with phone. Any help is greatly appreciated.
08-13-2024 09:42
08-13-2024 09:42
Hi there, @Dab1224. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 2 is locked. I understand your concern, I will do my best to help you with this!
As per the description of your post, it seems like your Versa 2 is no longer paired to your phone. That would explain why the time is incorrect and why you cannot unlock it with your phone. The only way we can bring your Versa 2 back is by performing a factory reset. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please follow the steps below to perform a factory reset on your device:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
Once you manage to set up your Versa 2, please sync it in order for the time to be corrected. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
08-14-2024 06:10
08-14-2024 06:10
08-15-2024 06:36
08-15-2024 06:36
@Dab1224 Thanks for getting back and the details provided in your post.
Since your Versa 2 is stuck on the Fitbit logo, please try the following steps in the order listed:
