02-17-2021
22:14
06:23
02-17-2021
22:14
06:23
My father's versa 2 is locked because he forget the pin code, and he removed versa2 in Fitbit APP, try to readd it back. But versa 2 screen does not show the BT connect code, keeps showing "unlock with your phone" , how can we do to unlock versa2
02-22-2021 03:36 - edited 04-07-2025 07:17
@Morin.M Any time!
To solve this issue, try the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer02-18-2021 01:13
02-18-2021 01:13
Hi @Morin.M Just checking (as you posted in in the Versa 3 Forum) you are asking about a Versa 2, not a Versa 3? In any case I think you need to contact Customer Support authentication device has been removed from the app.
Helen | Western Australia
Best Answer02-18-2021 06:19 - edited 04-07-2025 07:17
Hi there @Morin.M, welcome to the Community Forums. Thanks for sharing the details about the issue with your father's Versa 2 and for trying to troubleshoot it before reaching out.
To unlock the watch now that it's no longer paired to your dad's phone, I suggest to perform a factory reset by following these steps:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
I've moved your post to Other Versa Smartwatches for organization purposes.
Hope that helps.
Best Answer02-21-2021 23:16
02-21-2021 23:16
Hi Maria,
Follow the step you suggest, I think that I did initate the factory reset.
Trying to set up the watch, but now screen show "Data not cleared, Sync&try again" and APP can't find watch. What can I do for next step?
Best Answer02-22-2021 03:36 - edited 04-07-2025 07:17
@Morin.M Any time!
Best Answer02-25-2021 21:36
02-25-2021 21:36
Thanks. I can set up Versa2 now.
Best Answer02-26-2021 11:12 - edited 10-14-2023 14:06
@Morin.M Awesome! I'm glad to hear you're back on track.
I'd like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
