07-27-2022
08:09
17:44
07-27-2022
08:09
17:44
I need help to unlock the pin code in my versa 3
I bought the watch as is, I don't have the pin code
07-27-2022 08:12
07-27-2022 08:12
Hi @Giocza if you purchased second hand, the seller should have set the Versa 3 to factory specs before handing it off to you. These devices need a phone to set up and sync. Maybe check with the seller.
07-27-2022 08:27
07-27-2022 08:27
@Giocza A moderator gave this list of instructions to another user with the same problem.
Laurie | Maryland
