11-22-2022
		03:31
		16:58
		11-22-2022
		03:31
		16:58
It won't pair, I can not unlock it to do anything at all. I can not reset it. It is saying I need to authorize the internet, but it is locked so I can't oair it. I keep getting the UNLOCK WITH PHONE message but it's not paired so it won't unlock. I'm throwing this garbage away and buying a Samsung watch.
11-22-2022 08:02 - edited 02-24-2024 04:20
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @SunsetRunner. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 3 before reaching out.
Since you no longer have access to your old phone, I suggest to perform a factory reset by following these steps:
If you change again your phone in the future, please make sure to remove your Fitbit device from the phone's Bluetooth settings to avoid this from happening again.
Hope this helps.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer11-22-2022 08:02 - edited 02-24-2024 04:20
Hope this helps.
 Best Answer12-22-2022 01:54
12-22-2022 01:54
To unlock your device with your phone:
In the Fitbit app, tap the Today tab. your profile picture. your device image.
Tap Device Lock.
Find the option to reset your PIN code.
Regards,
Will
12-29-2022 01:28
12-29-2022 01:28
Tap Device Lock.
Regards,
Will
