06-20-2023
08:51
11:00
06-20-2023
08:51
11:00
Hello, I changed my phone and forgot my Versa 3 pin. How do I unlock it and connect it to my new phone?
06-20-2023 11:01
06-20-2023 11:01
Hi there, @Patryk4444. Welcome to the Fitbit Community Forums.
Since your Versa 3 is no longer connected to your phone, please follow the steps below:
If you change again your phone in the future, please make sure to remove your Fitbit device from the phone's Bluetooth settings to avoid this from happening again.
06-20-2023 11:01
06-20-2023 11:01
06-21-2023 04:08
06-21-2023 04:08
Everything is working now, thank you very much for your help
06-21-2023 04:52
06-21-2023 04:52
@Patryk4444 You're very welcome! I'm glad to hear your issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best Answer06-21-2023 20:53
06-21-2023 20:53
Had the same issue with not being able to connect to phone. App was asking for unlock code. Not exactly sure how I was finally able to unlock it, but it took quite a few tries to finally get it unlocked. It would reboot and then still be locked when it restarted. I guess I finally hit the button at the right time and it reset and the rebooted as when new. It also did an firmware update.
Best Answer06-22-2023 00:56
06-22-2023 00:56
Hi, My Versa 3 has switched off and won't switch on. It's been on charge, so I know that's not the prob. I've tried the 'reset' you suggested, but I've held the button in for ages and there's no vibration? Is there another way to factory reset please?
