06-01-2025
10:51
08:41
06-01-2025
10:51
08:41
My fitbit has locked itself saying unlock on your phone. I tried but it kept saying couldn't connect and then to try to reset it i deleted the device from my phone account but now cant add it back on because I cant see the code its sending because of the unlock message. Cant reset it with the side button as keep getting the unlock message coming up. Anyone have any suggestions?
06-02-2025 08:45
06-02-2025 08:45
Hi there, @Ailsastepho. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 3 is locked. I understand your concern, I will do my best to help you with this!
Since you no longer have access to your old phone, I suggest to perform a factory reset by following these steps:
If you change again your phone in the future, please make sure to remove your Fitbit device from the phone's Bluetooth settings to avoid this from happening again.
Best Answer06-09-2025 20:11
06-09-2025 20:11
That did not work 👎👎👎👎👎👎👎👎👎
Best Answer06-11-2025 06:48
06-11-2025 06:48
Hi there, @K3chdugoduc. Welcome on board. I'm sorry to hear that the steps recommended in the post above did not work.
I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly. Thanks in advance!
